I stand corrected, even at idle there is some vacuum loss to the PCV. But that is not the highest PCV flow condition (greatest vacuum leak). See the operation modes below:
PCV Valve Operation Modes
High Manifold Vacuum, Low Crankcase Pressure
This mode corresponds to the idle condition. The pressure differential presses the disk in the PCV against the intake manifold side seat, where the metering slots permit a regulated flow of gasses into the intake manifold. This flow is kept to a small amount so as not to decrease manifold vacuum level.
High Manifold Vacuum, Moderate Crankcase Pressure
This mode corresponds to over-run (coasting in gear with the throttle closed). In over-run, manifold vacuum can exceed 20 in. Hg. Under these conditions, the disk in the PCV is pressed against the intake manifold side seat. A small amount of flow is passed through the metering slots. Blow-by is minimal as combustion is at a low level.
Low Manifold Vacuum, Moderate Crankcase Pressure
This mode corresponds to part-load conditions. When the pressure differential becomes greater than the spring tension against the disk then the disk floats between the intake manifold side seat and the crankcase side seat and a large flow of gasses can be passed through the valve. This is the normal operating position of the valve when cruising under light to moderate part-load conditions.
Very Low Manifold Vacuum, High Crankcase Pressure
This mode corresponds to heavy load to full-load conditions. Here, most of the pressure differential that opens the PCV valve comes from crankcase pressure. Under heavy load, blow-by gasses are at a maximum and the PCV valve is open to permit the gasses to be passed to the intake manifold for re-burning.
High Manifold Pressure
This mode corresponds to an intake backfire condition. Here, the high positive pressure in the manifold presses the disk tightly against the crankcase side seat, sealing the PCV valve and preventing flame propagation into the crankcase to prevent an explosion.
