All Small Six photos of aussie head engine with Autolite 2100 carb?
Goldie
Does anyone here have photos of an installed 200ci with aussie head and 2bbl conversion specifically with an autolite 2100 carb? We are hoping to do our install in the next few weeks and are hoping to find photos that might show carb linkages, etc. with this set-up. (I know... I'm asking for a lot...)
Thanks in advance!
Well the Autolite should mount like my old Holley 07740 corrrect? The carb linkage is still on the passenger side?
All I did was bend my linkage arm towards the passenger side and lined it up to the carb. Everything fit perfect.
Now with the Aluminum head I use a Lokar throttle cable.
I believe they may mount the same. I was also told that we can rotate the mount 180 degrees depending on clearance. We are also running headers and have factory AC, so I know there will be some custom or modified bracketry in our future.
Do you have any photos you can share?
Thanks!
