Can you test to see if a pickup coil is working or not with the dizzy out of the motor xe 4.1, I had no spark at all, ive replace the coil and the module is ok and still no spark, i had a spare dizzy with no module so swap dizzys and put the module in and it fired up no worries, the only thing ive found with using this dizzy I dont seem to have the same power output as with the other my ute is and auto 4.1, I read some early posts where Alloydave gave some casting numbers on the dizzys, the one that ive got in is from a manual 3.3......#is 9-230-064-710 and the one that I had in was from and xd # 9-230-064-705 and this ran well until it pack in, can I swap the pickup coils over if this is the problem, also read where Addo said there a prick to remove, which is the best way to go here
The xd dizzy 9-230-064-705 can someone tell me if its from a 4.1 auto / manual or 3.3
Thanks Joip
Thanks Joip
