Was wondering if anybody has some information what the piston to valve clearance of a stock 200 with log head (any year, either small log or large log, stock cam) is.
I am aware that it all depends on lift, rocker ratio, cam advance/retard etc... I just wanted to know if anybody here has Maybe measurements already taken. Since the falcon handbook suggests that .090 can savely be milled off of a log head, I assume that there will still be enough piston to valve clearance after milling?
If anybody has numbers on different combinations (larger cams, ...) it would also be great to hear!
