I have two graphs which I researched from David Vizards work. Absolutely neat stuff. He listed about 13 variables which alter octane sensitivity. Check some work we've been doing,
http://fordsix.com/forum/viewtopic.php?t=12838&start=0&postdays=0&postorder=asc&highlight=
but
don't got bogged down on the detail. A few graphs will clear it up!
Not getting to big on the details, do like the Ford Falcon six performance handbook says. This is the Talmud for small six performance!
1) Exhast heat stove MUST GO! It needs a port divider to reduce heat soak, that will allow 8 motor octane numbers less for a start according to Vizard.
2) 0 deck the block or use 255 pistons to get a perfect 0 deck. Take a lot of the later head, and get a compression ratio into the 9's. Use the Schendahls compression ratio device.
3) Follow Mark P's advice on the head gasket type, and the amount of decking and high energy Duraspark ignition set-up.
4) Improve the carb arrangement to something that suits YOU. Personalise your engine to how you want it, but do the first 3 things.
I'm pretty sure the Ford 200, 250, and 300 engines often have to run high test because of these 3 things being so amazingly
wrong straight from the factory!
