Ok, here's the history....
Car would run fine for awhile, then hot or cold and randomly, while running or idle, would start shaking and shuttering while giving it gas.
Turns out the EGR Valve pipe was leaking bad. So I bypassed it. Neighbor took it too his shop, plugged the valve, and we plugged the manifold. Replaced all the vacuum lines and now everything is air tight.
Here's the problem...
Now its getting too much fuel. Opened the air/fuel mixture screw way open and still nothing. It will run for awhile, then it will you can feel and hear a random miss that gets worse for abit then it stalls out. It restarts right away, but you can definately smell the gas. Replaced fuel filter, the old metal fuel line, carb was replaced 3 months ago so doubt the float could have gotten out of wack that soon, new plugs, cap, wires about month and half ago.
Plugs are gap'd at .040 now, think i'm gonna raise that to .54 like fordsix has listed in his duraspark conversion tech pages. more fuel = more gap?
The occasional, random miss with everything engine wise checked, is also leaning me towards replaceing the duraspark 2 module. After regapping tonight, next step is replacing the ignition stuff.
Any ideas?
Car is 69 Mustang coupe
77 Granada 250 4.6 L I6
Duraspark 2 igntion
Carter YF 1bbl carb
Any ideas?
Duraspark 2 igntion
Carter YF 1bbl carb
