Problems
Hey guys i just got my carb adaptor in from clifford and my 32/36 progressive from langdon and i bolted them together and put it on and the throttle bracket isnt facing to the right like the stock. its facing more to the front right of the car anyone know how to make it face the right way.
Take off the nut and reposition. The end of the shaft is flat. The throttle lever has a hole that is mostly square. You can remove the lever and rotate and you can also flip it over and/or rotate to get it pointing the correct way, hopefully.
Take a look at the post I just made "Weber 32 36 Carb". You can just make out the position of the lever in my instllation.
Good luck, Ric.
