pully wheel power steering
question: is the pully wheel from an orginal powersteering setup pump pressed onto the pump ?
i did make a aluminium belt drive pully setup for the 6 cyl , i did use an smaller pump setup with remote oil cannister , but also wanted to make a setup for orginal power pump . so i must remove the wheel and make an aluminium wheel for it , wheel making is no problem , but how to remove the orginal wheel from the pump . i got a pully wheel pres here , but wanted to know for sure it is pressed onto .
it is a belt driven 30 M/M wiht theeth belt like the ones used for blowers . nice polisht alu wheels ,
Sounds like a sweet setup, that will surely cure the slipping belt syndrome 8) Not certain about the early pulleys being pressed on. Hopefully someone will chime in that knows.
Joe
