well then what is the best camshaft for my motor? I'm miss understanding something here... so I'm askign in this category...
I honestly don't know what I want out of the motor, as I'm not sure what I feel when I feel it...
off the line I like quick accelration, I want to spin tires, not just chirp them... and I want passing power with ease, along with good mileage (18+ mpg)
currently
9.3CR
264/274 110* cam .450 inch lift with stock 1.5 rockers
78 head with 2bbl directly mounted
holley 2300 series 350cfm carb
Head flow
http://i897.photobucket.com/albums/ac17 ... AN0001.jpg
Current Dyno Run (best result with 87* air temp)
now, what would be better? is there a better cam that will give more torque or HP and not loose drivability? should I go get the head milled more and bump the CR up?
my goal with this engine is always more power, but right now I would like reach 150hp. I'll set up a dyno run a few weeks from now, as it's getting colder it would be a great time to test the enigne with the best temp of air.
but what do you guy's think?
currently
9.3CR
Head flow
