'68falconohio
I know this has been discussed previously and I've searched the internet and the forum for rock-solid answers.
I'm building a 200 six with a highly modified log head(no log) for my daily driver. 15k miles/year.
My pistons are sitting .005-.010" in the cylinders(deviation due to stock components, didn't go through trouble of matching them) and I would like to use an OEM gasket for several reasons.
1.) improved quench/squish.
2.) I'm unshrouding valves so combustion chamber is growing.
3.) I want to leave as much meat on the head as possible.
This puts me at .030-.035" of static clearance between the cylinder head and top of piston(dished pistons with 5cc dish). Speaking with the engine builder that did my work previously, he said .035" will be tight and less could cause the pistons to kiss the head. I'm leary.
I'm not going to do any more cutting on the block. The engine is currently in my car and I'm 'only' going to swap in the head and related components once I have it finished. I had full rebuild 10k miles ago, which included a direct mount 2V head.
My goal CR is 9.3:1. Utilizing smoother combustion chambers, a good quench, and proper timing curve. I want to run on 89 octane. The combustion chambers of my E0 cylinder head are ~62cc prior to unshrouding/smoothing so I will have to do some substantial cutting on it to get my CR up.
I have a line on an OEM gasket for the 200 but don't want to get something that I can't use, and more importantly, don't want to my engine to scatter if the head to piston distance is too tight.
Anyone have links/info they're willing to share on quench. I've read CZLN6's posts on quench distance throughout the forum, and he has said .030-.035" would be ideal. I'm at a loss as to who to believe. I have great respect for CZLN6's contributions to us sixers and also great respect for the engine builder who told me <.035" could be too tight.
All suggestions/knowledge are greatly appreciated.
