Alright - think about it.
The way a carburetor works, all the fuel pressure does is keep fuel in the bowl.
To low of pressure, and the flow isnt enough to keep the bowl full. Too high of pressure and the flow will overwhelm the needle and force the float down, overfilling the bowl.
The needle+seat is a valve, that is controlled by the float.
In a NA application, the bowl is at atmospheric pressure, and is kept there by the bowl vent.
The Vacuum in the venturi of the carb (lower that 1atm) sucks fuel out of the bowl via the various passageways.
In a turbocharged application, you reference the bowl vent to the carb hat - so the pressure in the bowl is the same as the pressure into the carb. This means that the ratio of venturi pressure (absolute) to bowl pressure (absolute) stays the same.
The reason you need to increase the fuel pressure into the carb under boost is that, as you use fuel, the bowl needs to be re-filled.
If the pressure ratio between the fuel (absolute) and bowl (absolute) becomes to small, or goes negative - you will not get fuel flow into the bowl and will starve the engine of fuel.
So If you are at 1 atm (14.7psia) and your fuel pressure works "right" at 5 psig (19.7 psia) then, as you add 1 lb of boost, you need to add 1lb of fuel pressure to keep the ratio correct. There is probably some wiggle room in this, as an example I have no fuel pressure increase and my ranchero runs mostly o-k (because I am not draining the bowl under boost, yet)
But if I were to stay boosted for a long period of time (more than a few seconds) my bowl would drain and I wouldnt have the deltaP between fuel line and bowl to fill it up.
Infact, I probably have negative - so as the float opens the carb starts to flow BACK into the fuel line.
Get it ?
