David_Conwill
1) Reading the Schjeldahl book, I’m pretty concerned about the Spark Control Valve/Load-o-Matic interface. They strongly urge that when changing the distributor out for a later one, the carburetor must also be changed, and vice versa.
In my plans to build a 200, I’ve been thinking in terms of using a Duraspark II or a ‘68-style points distributor converted to electronic with a Pertronix kit. But I’d also like to use an Offenhauser or direct-mount 3x1 setup with Holley 1904 carburetors.
Is that going to work? I think it should, since it appears to be the same situation as adding more carburetors to a ‘49 to ‘53 Ford V8: You can’t use the stock-type distributor, because the vacuum signal will now be wrong, but there’s no problem using the stock carburetor with an electronic distributor, because the dizzy doesn’t provide feedback to the carburetor.
2) How do I know the proper 1904s when I see them? I assume the intent with the original Offy and Edelbrock triple adaptors was to use OE-type carburetors for the 144 and 170, so how do you know that the glass-bowl (or zinc-bowl, for that matter, I’m not particular) Holley you just drug out of the greasy milk crate at the swapmeet is a 1960 Falcon 144 carb and not for a 1956 F100 223? I haven’t found part numbers yet, but that’s what I’d like.
Thanks in advance,
Dave
Thanks in advance,
Dave
