Questions on the OZ 250 head and plans for my 200
I was considering going with a Stage II build-up as suggested by the Tech section, but I'm starting to become attracted to the Oz 250 cylinder head. I've heard nothing but good news about it! One site I read even boasted a 40% increase in power with a 2bbl carb, Oz head, and headers. That got me very excited, because it's very similar to the setup I've been thinking of lately:
- Oz 250 head
- 2bbl carb (not sure what kind -- suggestions?)
- 6-into-2 headers
- Flowmaster mufflers
- Hydraulic cam
* I'm also considering going with the Tempo 2.3L pistons after gaining some more intel on them, and a future ignition/distributor upgrade.
Here are my questions:
1.) Where can I pick up an Oz 250 head, and how much do they usually go for? I tried researching on eBay, but had no luck.
2.) How much should I expect to pay a machine shop to work it over?
3.) What work would the shop need to do? (Asuming there is no critical damage done.)
4.) What carb should I go with? Should I go with with 2'' dual pipes, or get bigger with 2.25'' or 2.5'' dual pipes?
5.) What does Clifford's port divider do? (I think I have an idea, but I just want to make sure.)
6.) How do I decide what push rods I need?
Thanks for helping me out! Answers to any and all of these questions is appreciated.
8)
Look for the post not long ago by Mustangaroo. With very few modifiations on his 200 he went from about 67rwhp to 105 rwhp. After he put a bigger carb on the engine tested at 107rwhp. No cam, no big carb at first, no big compression increase.
So yes there is a major increase in breathing. So if you get the Oz head, Add a cam, header, a good size carb for the engine, a high energy ignition, and mill the head to raise compression and you have a nice little motor.
He's got a lot posted on the Oz 250. I'm gonna have to go through those and try to learn a thing or two.
On milling the head: how much should it be milled? Any idea what the compression ratio would be?
8) You should have the head cc'd first. It is a way of measuring the size of the combustion chamber.
Most of the guys have had .050" to .060" removed. This should raise compression by about 1 point, ergo 8.5:1 to 9.5:1
8)
I have a Oz 250-2v with the intake converted to a Holley 4bbl. I have to get it back from my dads in Florida. My rebuild is currently on hold since it is winter and I dont have a garage.
