Hello,
I've got an issue I was hoping someone could help me with. I've got a 65 200 ci Mustang with a radiator clearance issue. The car came to me with a 2 row radiator and large 6-blade fan. The only copper replacement radiator I could find was 3-row, but it will not fit with the existing fan. I was able to get it to fit with an OEM 15" fan by eliminating the spacer, but clearances are still too close for comfort.
I did a search and found a couple of similar issues, but I'm still at a loss. I'd like to keep a stock look if possible. I think part of the problem is the mounting brackets sit flush with the front edge of the core. The old radiator sat recessed in some (to the front). Could I get a shop to relocate the brackets?
I also read a suggestion to shift the engine back some on its motor mounts. Is this possible? Will there be enough "play" in the driveshaft to allow this? How can I tell?
If anyone has any tips or suggestions, I'm all ears. This is very frustrating. Here are a couple of before and after pics, assuming this works:
Before - http://automotivedaydreams.files.wordpr ... _1109b.jpg
After - http://automotivedaydreams.files.wordpr ... 05512b.jpg
Thank you,
Jason
Thank you,
Jason
