philford
maybe you need an oilclot additiveit's a drip for now, not a puddle. BUT i just remebered i added 1 qt of synthetic oil last change to see what would happen... now i know =)
Wakjob, X2 I am talking about the bolts that hold the flex plate to the crankshaft it's the same thing for a flywheel too. All six of those bolt holes in the crankshaft flange are drilled and threaded all the way through the flange and are therefor open into the crankcase. The only differance between the bolts for a flywheel (bolts are about 7/8 inch long) or a flex plate (bolts are about 3/4 inch long) is their lengths.
It is a '74 Bronco with a 200 inline six. It has 110,000 original miles, and is still sporting the original paint job. I did a decent amount of work on it this winter (see here) that started as a rear main leak and clutch replacement. It of course snowballed once I pulled the engine. It now runs like a top.twodogs is that an international scout or an early ford? i had a 63 scout when i was young. loved it. always wish i kept it. it would climb like a goat even with just half a V8 and no compression. fond memories. maybe its a early bronco. had a friend with one. they look similar. rare now.
If you use the neoprene, I've read you need to be careful rolling it in so that you don't shave off some of it due to the sharp edge on the block. I originally planned on using an Permatex anaerobic sealer but I ended up following the steps wsa111 outlined on page one, so I stopped by a Toyota dealership and picked up a tube of FIPG. Just a dab of it on the ends of the neoprene seal, as well as a small amount on the block where the main cap bolts down. There's a good pic of where to place the sealant in a Chilton's manual.Ok...got both rope and neoprene seals (haven't decided which one yet)... and the rear main tool kit from NAPA.
It has the corkscrew tool, clips, ect...
Someone told me to get some jelly like lube (Astrolube or K/Y) to help it go up and around the crank.
The instructions say to just soak it in some oil for a few minutes just before installation...
Any tips?
Mine turned out great, without any leaks at all. I no longer have to put anything under my rig to catch extraneous drips. My experience with replacing a rear main seal totals up to exactly one….so perhaps I got lucky. The tips by wsa111 sure helped me.How did yours turn out?... any leaks?
Thanks, Wak
As wallen7 mentions above, if you go with the neoprene seal, you will need to drive out the small pin in the bearing cap. And just as importantly, you’ll need to put a dab of sealant in the hole where the pin used to be.
I HATE leaks so I was pretty thrilled when I put everything back in service, only to find my garage floor remains clean. I was in the shop today and took a couple of pics of the procedure outlined in my '74 Ford Service Manual for the 200 cid. I figured I would put them on here, since the pics for seal positioning and sealer placement was critical. You may already have these but let me know if you need more. And definitely....good luck!RIGHT ON!!! CONGRATS MAN!
I'm going to stop by my local Toyota dealer and grab some of that sealer and give it a go following wsa111's steps also.
Wish me luck.
The FelPro neoprene seal that I used said the exact same thing. I'm assuming mine would have sealed fine without a dab of sealer on the ends. However, I went ahead and did it since wsa111 recommended it, and it appears he has plenty of experience in this arena. Perhaps others will chime in....I bought the Corteco 17042 neoprene seal.
It says to NOT put any sealer on the ends where they meet.
