JGTurbo
Sorry for the slow reply. It's dead week for me (week before finals). I'm working on four projects and also cleaning up a little TD03 turbo (~60-140hp) that arrived on Monday.
I think I'm done disagreeing with you two (for the moment
). I am very impressed by your responses. I'll read your posts again and do some more thinking on the subject. If I find something that I can't pass up I might dig into this again.
Thanks again for the great discussion guys!
But not if you run the cooler gas through a smaller hole.CobraSix":mli41rms said:Cooling of gases does decrease pressure.
Along with less lag, you would see a restricted top end of the powerband. It would be like running too small an A/R. As far as seeing more boost, I'd say more boost sooner, yes, but I believe a rear mount turbo can still run the pressure ratio up to a level where the compressor efficiency is the limiting factor. I see your point on efficiency, but I've never heard of a properly sized turbo running out of exhaust energy.StrangeRanger":mli41rms said:You can obviously size the machinery to work as a rear mount, it has been done. But if you were to take that same turbo and mount it under the hood where it belongs, you would see more boost and less lag.
