8) SR is right. turbos really airate the oil that passes through the bearing, and any back pressure will not allow the air to escape, allowing metal to metal contact, and with the turbo shaft spinning at 40,000 rpms it will destroy the bearing very quickly. most turbo builders use a 3/8" pressure line to feed oil to the turbo, and a minimum of 1/2" line for the return line. most race engines use something more like 3/4" return line. in any case if you dont mount the turbo above the oil level in the oil pan, including the drain outlet, you WILL have a bearing die a quick death, taking the turbo with it, unless you have a high volume pump to scavenge the oil from the turbo housing. something else to seriously consider for those of you planning a turbo install, use an electric oil pump on both sides of the turbo, and set them up on a timer to run for a couple of minutes after the engine is shut off so that the bearing is not subjected to 40k rpm with no oil pressure. that will wear the bearing out as well as allow the turbo to coke up.
