Falcon Ranch
I am finally finished with my 212 rebuild on my '61 Ranchero and am now looking into doing a rear mounted turbo system...I have two reasons for this...one being that I will not have the heat of the turbo in the engine bay and second, by using aluminum tubing for the return...it would be like having a built in inter-cooler while under boost.
I have a turbo my brother gave me that came off a Unimogg military truck that had a V8 diesel, it's brand new...so I know it's plenty big enough since it only pushed 4 cylinders.
I want to keep it simple and go with the draw through route...I am considering mounting the Holley 350 in the back of the truck and running a long throttle cable...I believe that the car will still run fine though the carb is mounted at the back...what do you think about this?
Another option is to remove the carb off the log all together and mount the turbo and carb where the battery use to be and just run my pressure tube to where the carb use to mount...this would move the carb closer to the engine...is this the better choice?
Unless pressurizing the Holley 2300 series carb is simple :roll:
Dave
Dave
