I thought I almost had it…
I need to make a new pan for the bronk 250 soon - with rear sump to avoid the front chunk. From another discussion I gathered there were a few years of the above. The bronk even had a 200 for 2 yrs. I reasoned if I got an oil picup or more importantly the tube, I could make a rear sump for the 250. I thought it would fit, from the 200 into the oil pump bolt up area - fashion on the old or the correct 200 pick up/screen. jimmyv65 just cut off the front of his 250 pan and welded/brazed a flat plate across there. I will be on the gradients and don't trust this solution…
Can folks tell me if this would work. The engine assembler can braze the 170 (rear sump) pan and 250's 'ring' together. Do you think the long tube seen in Jackfish's 200 to be the missing link to this. Some have said "Just bend the tube around" but I fear brakage, kinking, etc. bubba has expressed the importance of 1/8th to 1/4 inch hight above the pan's for the proper pick up of oil there…
All is planning only - as the motor is not in yet but I want to be prepaired for that step before hand so as to reduce the friend's other problems as he helps me install. A solution (pick up in hand) could go a long way in this process ~
Thanks for your "experienced brain" loan!
