After a couple wiring hiccups I got the engine running ran for about a min and shut her down
Oil pressure was hangin out in mid-upper 50 psi range at 2 grand area, using brad penn 30 weight break in oil, good right?
Next thing was interesting, were certain that the starter was stuck on the entire time but exhaust was covering it up till I let up to idle for sec and then we knew something was up so we killed it, did some wiring checking, in another thread we talked about ignition wiring. The one thing was running a wire from the S terminal to the + on coil for full voltage on start. With the ignition on this wire is giving the S terminal 5.5 volts and there is 0.11 V at the terminal going to the starter, is this causing some issues with the starter? The starter wining is a pretty distinct noise so I hoping/praying that's what it was.
Lee
Lee
