Last night I pulled the carb from the Maverick. It’s a Carter, model YFA carburetor on a 200 I-6. The first thing I noticed while removing the carb is the metal choke heat tube that connects to the manifold is broken just above the manifold. This tube is covered with a fiberglass mesh kind of sock, so it was hard to tell it was broken until I disconnected it from the automatic choke. So my first question is, does anybody know what the part number is for the choke heat tube? Is that a part I can still order? Took it to the local auto parts, the guy there said it looks like standard brake line material, even the connection at the carb, could this be true? And, I’m really nervous about how to remove the broken “stub†from the manifold without really screwing something up. How is this tube connected to the manifold (it’s pretty rusty so I’m not sure from looking at it)? Can I drill it out without causing problems?
Now that I have the carb off the car, I’ve taken a close look at the carb kit and all the small parts & gaskets. I'm a little freaked out and wondering if I can really do this. The kit came with an “exploded view†of the carburetor, listing what the parts are, but it really doesn’t have “how to, step-by-step†instructions on how to tackle this. Does anyone have step-by-step instructions on how to rebuild this carburetor?
Thanks for any help you can offer...
Art
Art
