ok im seventeen and i totally blew my 200ci in my 66 stang i wanted to know hows the best way to rebuild the engine with a lot more tolerance and performance i was thinking .030 bore with thos 2.3L HSC pistons a crank undersized 10-10 with .010 bearings, .010 rod bearings a 1980 head with a 500 cfm holley directly mounted to the log, reconditioned rods, a hi-po balancer, new oil pan w/ windage tray, new oil pump and pickup and full roller rockers with dual roller timing chain, dual springs oil through lifters and oil through pushrods with a 272 lift cam, duraspark II or mallory distributor and a msd control module AL
wanted to know if i have the specs right and if someone could correct me if im wrong pleaseeeeeeeeeeeeeeeeeeee
