62Ranchero200
Just installed a rebuilt Autolite 2100 2V on my 200 using the 1V-2V adapter from CI. The
Autolite is a 1962 vintage 1.02 ( = 245 CFM), complete with automatic choke. I used a new inline fuel filter (screws into the fuel fitting on the carb), a lokar throttle cable, and a homemade throttle cable bracket.
To give a bit of background, it's a recently refreshed '79-80 200, stock bottom end, Large log
head with pocket porting, Clay Smith 262H cam, DuraSpark II with wear issues (soon to be
replaced), and Pacemaker headers. With the old carb (an emissions Holley 1946 1V), the 200 idled well enough, although there was some roughness in the idle (I think partly due to the cam, and partly to distributor bushing wear). Once warm, the engine would never die at idle with the Holley. The same gas, fuel pump, and fuel lines are in the car now.
With the Autolite 2100, the engine seems to cruise, rev, and accelerate well, but won't idle any lower than about 1,100 RPM. If I set the idle any lower than that, the engine will idle for a short time, then stumble and die.
Have done the following so far:
Checked the timing without vacuum advance: 12 degrees initial advance, as I expected
With the vacuum advance connected, timing is being advanced as I expected
Adjusted the idle mixture screws (there are two of them), no discernable difference
Opened the choke plate by hand, in case the engine needed more air at idle - no difference
The only possible cause that occurs to me is the idle passages are clogged with a foreign particle. If the power valve wasn't getting vacuum for some reason, and so was stuck open, could that cause an inability to idle?
Note: seems to idle a little smoother if I leave a vacuum line disconnected, allowing a small vacuum leak.
Thank you,
Bob the Builder
Thank you,
Bob the Builder
