flash_point01
So I finally got my recycled DSII in, took her for a test drive and I noticed a certain amount of rattle at the high point in the RPM range. I don't have a tach so I can't pin point the RPM's but its nearing the limit. I also noticed a little squeak or squeal when i first take off. Is there too much play in the shaft, bent, otherwise FUBAR? IS this something that can be fixed? After calling many mechanics in the area none of them have or know about a Sun machine to test it on. The bushing looked to be in good condition, same condition as the LOM. There was a cartain amount of vertical play in the bushing shaft, from the bottom of the housing flange to the bottom of the gear. 2.510-2.515" when thw play is pushed up against the housing. Any thoughts?
