Hey all,
I have killed 2 ignition coils in the last year. The first one took me a long while to diagnose and the second one never totally died, the resistance changed significantly and I tossed it before it left me stranded. The one I have in now stumbled once and died twice last night. I can't figure out what's causing this. The coil I have in now did the first 20 miles ok but on the way home it died those two times. When I got home I measured the resistance and it was 5.47 Kohms while MSD lists it as 4.7, so the resistance is already changing on the way to ultimate failure.
Are there any "typical culprits" in this type of a situation?
I am running a 200 I6 with points and a ballast resistor hooked up before the + side of the coil. I bypassed the resistor wire. Plugs were recently cleaned and regapped to 0.040.
Any help y'all can give is appreciated.
-Dan
-Dan
