hello the oil slinger was un repairable, so i made a new one from sheet metal,coffee can. the oil seal had made a grove in the damper, i brought a gasket set which included a sleeve, following suggestions on the forum, i put the damper in the freezer for about 6 hrs, heated the sleeve with a heat gun, slipped on easy.replaced seal put it all back together quiet smooth ride cheers 8)
