I had a problem with smoky startups, smoke on the overrun etc as well as high oil consumption - for a long time I was waiting for the engine to die but then diagnosed it as valve stem seals after a bit of web research.
It took a while before I got up the courage to takle the job, my biggest worry being the idea of pressurising the cylinder to hold the valves in place...most sites and manuals suggest making an adapter to screw into the spark plug hole which is pressurised via an air compressor - I didn't have a compressor handy and was also worried about all the warnings about if you push down on the valves at all you run the risk of dropping them into the cylinder, so I tried an alternate approach I read on a different page - cheaper and, now that I've done it, I reckon much safer - you buy yourself a nylon clothesline type rope, feed that into the sparkplug hole (lots of it!!) and then wind up that piston until it compresses the rope against the valve heads - sounds shonky but works great!! Also, on one or two valves that had sticky colletts I did end up pushing the valve off its seat but because of the nylon rope you can feel it spring back up again - this would have been a disaster using the air method.
The other thing I needed was a valve spring compressor - I made one myself but I wanted alot more control than the typical lever ones you see around the place - the one I made uses a screw thread setup to push the spring retainer etc down - this allows you to leave the spring compressed at any height you need, with no chance of it moving. The tube that pushes down on the valvespring top also has a `window' cut into the side of it so you can access the collets through it, and also prevents the collets being dropped into the engine ...
If anyone can reply who knows how to insert photos I took a few pictures as I went so I could put these up if anyone is interested - this also took place on a 2v engine but its exactly the same as any 170-250. If its too hard to insert a picture send me your email address and I can email photos direct...
