I dont know if this is a commom problem but when I went to fit my "bolt on"
adjustable roller rockers I ran into some trouble
They bolt on fine and work like they should but when the time came to fit the rocker cover the dramas began the bl
dy thing wouldnt fit because the roller rockers were too tall, I first thought that it was just the cable relief so I had it cut out and a plate tigged in
Back at home I tried to fit it again but had no luck the cover just had no room so after many curse words I went and got some 10mm alloy plate and made a spacer to fit between the cover and the head now all is fine
[/list]
