66 200 with 1100 carb. The car starts right up everytime. It just wants to idle rough and miss alot. It has done this since I got the car. Here is what I have done so far to try and correct the problem.
Installed new Dist Cap, Rotor, Wires, Plugs, Fuel filter, Pvc, Electronic points
Checked for vacuum leaks. None
Ran a compression check and all cylinders are approx 125-150. Between 1 & 2 there seemed to be a slow leak so I replaced the head gasket ( Felpro ). The old gasket looked fine and so did the valves. The car does not smoke.
I took it to a shop to see if they could come up with an answer and the only thing they suggested was that my distributor might be the issue. They said that the rotor seemed real loose. If hold the rotor in your hand you can twist it a good .5 inch. Is this normal?
Any thoughts?
Any thoughts?
