Hello, I have been wondering why my car all of a sudden started with this problem, well actually the day after. I had set up the timing, which I also wonder if it is normal for the speed to increase once I time it with the vacuum advance off and plugged, set it to TDC, then plug the advance back on, accelerate and it will jump to the middle and a few times it will jump to the very top, what could cause this? Well anyways, I took the car for a spin and it reacted very well. The next day it was colder so I had to use the choke, and the car felt different once it turned on, it was idling rougher, I thought maybe it was cold so I let it warm up a little longer, went for a spin and the car felt the same. I'm not sure what happened!! I replaced the manifold prior to the first run but now the car runs shaky with the choke all the way in. I have timed it, I cleaned the spark plugs which were sooty, played around with the idle and the carb but it still does it. If anyone can tell me anything to solve this I'll greatly appreciate it. Thank you.
