rubber rear main seal question
Has anyone ever put one of these rubber split rear main seals in and are they worth it or should I just break out the rope for another few thousand miles till it leaks again? over and over again pulling the engine to do so.
I got a rubber and it is fine. although make sure you put sealer on it and on the ends. I learned the hard way and had it leak on me
thanks for the reply . I won't forget the sealer on the end but what kind did you use?
Gray RTV?
Adam, this is from a previous post, & it seals to perfection. William
Hope this helps, install the rear main seal with the ends at 10:00 o'clock on one side & 4:00 o'clock on the other side. Then put a small daub of sealer which you need to purchase at a toyota or lexus dealership. Its called FIPG. Put a small daub at the butting surfaces of the neoprene rear main oil seal. Before you put the rear main bearing cap in place place a very small bead of this sealer at the outer edge or lip where the rear main bearing cap contacts the block. Also place a very small bead from the seal to the outer edge where the main cap sits to the outer edge or where the cap contacts the block. Don't forget to place sealer on the flywheel or flexplate bolts to the crankshaft.
Using this procedure i have never had a rear main oil seal leak or even seep. This applies to fords & chevrolets, big block or small block with the 2 piece rear main seals. william
