Running Numbers
strat1960s
I work late into the night and got up early this morning and worked some more.
Finally I got in and fired up the motor.
Here are my numbers:
Temp: 180
Oil Pres: 42
Volts: 14
Idle RPM: 1100
In gear Idle RPM: 950
She sounded great, and ran very smooth. I found a small coolant leak at the thermostat housing. I will need to replace that gasket later today, maybe tonight. I hooked up all my vacuum hoses including my trans vacuum modulator. Maybe before I fix my coolant leak, I will take her for a drive around the block.
I'll keep you all posted on any changes.
Thanks for all of your help.
Ted
