So we have all been through this with me before, sometimes my engine runs like a dream and sometimes I can hardly keep it running.
I have posted lots of topics on this, we have been over many things, but I am thinking I am back to square one on this now that I have sealed up the intake and exhaust for sure. I should start back at the beginning.
So over the weekend I installed FSPP gaskets on the 2v intake and headers... I spent a lot of time making sure things were clean, surfaces mated fine, bolts were tight and everything is sealed up nicely. I know I was partly successful because the car runs much better, at least when it is warm and dry. The rpm range from 2-3K is usable now, shifts are smoother and the power curve feels better. Not 100% yet, because I know I am all in on the timing too fast, I need to get the distributor re-curved or replaced with one that better suites my setup.
Here is what caused me major trouble today.
It is cold and rainy here in ATL... temp is 33 degrees and raining lightly. Now for me the cold has been bad on things but nothing compared to the rain.
When the temps are low, I can close the choke and get her to warm up at around 1600 rpms, you can watch the temp needle, what happens is it warms up and then when the therm opens the temps drop and it warms up again, at some point it holds a steady temp. (This has always been normal with this car, there is a point at first where the engine internally gets warm but the coolant that flows in the first time cools the engine back down.)
When this happens the rpms can sometimes drop down to 1000 or 900 or so with the choke untouched. If I open the choke the car dies, the engine is very rough when this happens. If I shut the car off and let it sit for a few minutes then close the choke part way and it will fire up nice and smooth. runs a normal cycle, it only seems to die once and a while during that first drop in temp. And always runs fine if you let it sit and warm up without running.
Now this all gets MUCH MUCH worse when it rains. Today right from the first moment, you close the choke and does not want to run, it idles really poorly, very rough, no position of the choke makes any difference, closed it will not fire, open it fires then dies, halfway where she normally loves to warm up it runs rough and dies. I popped the hood and pulled the aircleaner, opened the choke and got in, fired it up and held the throttle for a few moments just to get things moving, then it finally idled but was not happy at all. I am pretty certain this is not a great way to run a cold engine but it seems the only way to keep it up in the high rpms, because with the choke where it would otherwise idle at 1600 only gives me an idle of 900? no matter where you put the choke?
My first reaction is to give the car a proper tune up this weekend, I changed those manifold gaskets, and did a halfway tune on it, checking the vacume and setting the rpm at 800... but I am sure it could use a new set of plugs, and some timing and carb setting... seems like it is a little lean right now.
But I am not sure why the wet weather effects this, it can be 32 degrees and raining or 19 degrees and dry and it runs better at 19...?
I am also wondering if it is not running too cold... I am not getting the best readings with the thermostat I am running, I am going to buy a mechanical therm at Autozone and see what my real temps are. I will start there and maybe next time it is cold and rainy I will hook a vac gauge and timing light and tach to the engine and get some readings of what is happening when the car is like this.
I also get a squeal when I do hold the throttle, I thought my squeal was a bad powermaster alternator I replaced three weeks ago, I used to get this same thing with the bad alternator, but I replaced that and the squeal and this symptom stopped for a while, but it was also warmer here lately... but today it squealed again? maybe I have a loose alternator belt? could be when I changed the gaskets I did not get it tight enough? because I also was reading 11 volts when this whole idle problem was occuring?
I am also wondering if I did not get a bum Holley, and maybe this 350 is just not the right carb, I am thinking about going up to the 500 and see what happens...
could it be this 2v intake when cold I am flooding the engine with fuel puddling? I am just trying to figure this out, winter is almost over for me, and I am starting to wonder how this will be when things heat up?
man sorry this is long, but you know me things are never easy.
Thanks Guys...
Jimbo
Thanks Guys...
Jimbo
