"I'd like the idea of forced induction."
I'm always looking for more Forced Induction advocates and advice , here's my .$ .02 from previous thread:
I run a Maverick 250 with a centrifugal supercharger in Blow-Thru Carb config', been reliable for @ 2 yrs (2K m ?) . Working on boost vs RPM curves with pulley 'gearing' and pressure relief 'Blow Off' valve. Has stock pistons, cam, ARP head bolts, 302 springs 2X1 adapter and Holley 2300 . AFR's are good through RPM range. Ignition is advance limited. Un-milled OEM iron head with typical @ 62cc chambers yield SCR @ 8:1.
Runs with no faults with boost up to @ 5-8 lbs. Higher boost significantly increases detonation and blow-by
concerns. At @ 3.5 K RPM can easily pass 10 Lbs with current SC ratio's and
often does...
have more boosted fun
Ford Small Block Six 250 CID inline . Stock block and cam with measured and worked 62 cc chamber head, HD V8 valve springs, ARP head bolts. Holley 2300 - 7448 2Bbl heavily modified for blow-through/ boost, Aeromotive 1:1 boost referenced regulator and FI electric pump and return at tank. Flame Thrower rev-limited HEI ignition - DS II distributor modified for vac and centrifugal boost advance limiting. Vortech V-2 centrifugal supercharger with pulley ratio spec’d for inline six 250' powerband. Centerforce weighted clutch, T5-Z 'Cobra' 5 Speed, 3.80 rear. AM radio and bench seat.
