Serpentine Belts/Blower drive
2nd.gunman
Was the EA 3.9 the first engine to receive serpentine belts? i want o fit a serpentie system to my XC X-flow, but was unsure what model car to get the setup off and if it would fit my engine. I currently only have one belt for the alternator, but was looking for a setup that could be used to run a roots type blower as well. Possibly using the belts for either power steering/air conditioning or both to run the blower. Also does anyone know of a bracket(s) that could be used to mount the alt lower.
Gunna,
The EF was the first to run the serpentine drive belt that drove all with one belt.
Noel
It will take a Harry Huodini Act to fit one.
The E-cars had a side mounted water pump outlet, and the front cover of the engine was totally different.
:hmmm: But if you can get some free time at a car wreckers to inspect a later snake driven number (with a set of dividers, a straight edge rule,camera and such like) then you could duplicate the set-up on an OHV x-flow.
And doubling up such a drive with two belts is a cheep way of getting easily got components for a conversion. Just look at how easily the Supercharged Ecotech 3800 GM engines were hooked up. No point in being stranded on the Nullabor with a broken Gilmer belt drive that you don't have a hope in Hades of getting. You'd make a Burke of yourself.
Well, you can buy Gilmer setups for the Red and Blue donks. I bet they're available for the crossflows. Passed on a used Gilmer rig (Red motor) for $150 - they're out there. Nose around and you'll find something.
Adam.
