As many of you know, my brake and fuel lines recently wrapped around my driveshaft. I've completed replacement of those items and the brakes work fine. But now I cant get the car to idle. at all. In fact, the best I can do is run it at 1500 at about 1/4 throttle. anything less and it dies instantly. It is worht noting that that is about the transition point in the throttle between the idle circuit and the main circuit
When I got the fuel line repaired and ran the pump, a bunch of schmutz washed into my fuel filter. That's when the problem started. Today I took the carb off, took the top off, removed the idle, main, and air jets and emulsion tubes and the idle mixture screw, the fuel screen, and float. Cleaned everything throroughly and sprayed out all the passages. Set my float level. Put it all back together and adjusted it to baseline and it behaved exactly the same. This is a real bummer because the day of the tragic self-flagellation it was running the best it has in the four years I've had it. What gives? Oh yeah, its a weber DGES 38/38.
