Today i got a free engine and transmission from a '70-something Ford Maverick. I have no clue which engine it is, and the tranny is an auto, i'm guessing a C4 because of its small size. The 6-cylinder engine is quite smaller than the 300-6 engines that i have seen before. How can i identify which engine and transmission it is? Is there a list of casting on the internet? And where are the casting numbers located on the engine?
The guy i got the motor from said that he pulled the motor out of a Maverick that was running and driving great, with no smoke. A tree fell on the car and totaled it. The motor was pulled out 7 years ago, and sat in an garage since then. It is complete from air cleaner to oil pan. Carb, intake, starter, water pump, distributor, plugs, and wires, its all there. And the tranny is still hooked up to it. Since the motor isn't locked up, i was planning on changing the oil, then running a rubber line from the fuel pump inlet into a can of gas, and hooking up some jumper cables to the engine block and starter and try and start it up. Is there anything else that i should do to a motor that has sat this long?
I was planning on putting this engine is a go kart/dune buggy, but i may sell it. How much would it be worth, complete and running with a good auto tranny hooked up to it?
Thank you for any help.
Lucas
Lucas
