I use a short nose water pump, late two groove balancer, and the custom two groove overdrive
pulley I drew up
plans for and had my brother cut for me. It's cut smaller in diameter so I can use the late damper, and being smaller, spins the pump faster at any given rpm (great for A/C).
The short nose pumps themselves are still available at any parts store.
Single pulleys are a junkyard or eBay item (remember that old JY stock short pulleys will interfere with a late damper), but, it looks like Mike is now
selling the custom two groove overdrive pulley. In addition, looks like he offers them anodized and hardened. I would recommend the hardened version if you plan on using the pulley in a daily driver. Mine, which is made from a leftover, unhardened, chunk of 6061 is wearing away significantly. Mike is only asking 55 bones for a custom and
hardened (+ $10) pulley, sounds like a screaming deal.
You'll save about one inch total using a short pump. The long pump is about 3/4" longer, pulley mounting face to pulley mounting face, but the shaft extends out further than on the early pump.
Rick(wrench)
