candyapple66
Active member
Hi all-
I fired up my engine '200ci' after the rebuild and I used break in oil ran the cam in for 20 min then idled engine for about 20 and drained the oil. Today two days after with fresh 10w-30 high zinc oil i let the engine heat up then removed the valve cover to look at the valve rocker movement and noticed some light smoke coming out of a few (2) of the rear pushrod holes. Why would this smoke be coming out of the lifter/pushrod holes? Should I retorque the head to spec? Blown head gasket? Lol
