motocentro":2wkvt1zr said:
Anyone know anything about Fish Carburetors?
I hear they are pretty amazing where fuel economy, tuning and performance are concerned. . . Like - there's only one gasket to change, no venturi and no float bowl system.
Any thoughts or knowledge? I'm considering buying one (two, actually) and I am trying to do some online research but I'm not coming up with "enough" info for my own satisfaction.
-J
The only source of good information I have read is the first and second versions of the David Vizard books on the A series Mini engine. In it, he commented on his inability to make the 1.5" Fish work as well as an 1.5" SU. He commented that the Fish did produce admirable power at certain points, but that the air fuel trim was hard to tailor throughout the rev range. The pluses were the adjustability, so he affirms the fact that the carb has ability to reach power and economy and adjustability, just that it was a unstable and not repeatable. That's why I say as a fuzzy logic feedback carb, it could be really good.
Standard, the Fish carb is only good for two factors, , performance and adjustability, or economy and adjustability. Performance and Economy and adjustability are not able to be reached at any point.
The real clincher was when Mechanical Engineer Vizard decided to let loose with a few modifications to improve the air flow and fuel atomisation. The results ruined what air fuel adjustability there was. Hence the very disturbed flow and blunt edges of the Fish carbs swing arm are all there for a reason, and a lot of science has gone into it.
Again, I repeat, it is like a fighter plane...its easier to control the swing arm and its fuel dispensory with its seamingly dumb a$$ blunt edges and big swiss cheese holes with its unstable and seamingly preverse blunt flow. Fighter plans use computer control in a super crtical state to ensure a sub crtical air flow never causes yaw instability. And so it is with the Fish carb.
Do a web search, and buy a copy of the Vizard A-series book, or rent one form a library. That is a pivotal discussion on the carb.
If you've got some two carbs lined up, I'd create a servo for triming the fuel air ratio, and link it to two wide band oxygen sensors, and go have some fun. Don't try to re-invent 20 years of development, but be dumb enough to figure out how to tune it, for it is really easy to tune.
As for details, Vizard book, Vizard book, Vizard book....
