spark plug read
Guys, hope you can help me read my plugs. I've looked at all the charts, etc, cant seem to get anything to match what I've got. I can put in new plugs drive 50 miles and I have a bright black spot on my insulators (the white part). Car runs fine at speed, at interment miss at idle. the plugs in cylinders #2 and #5 look worse that the rest. If I run 100 miles #2 and #5 appear to be gunked up w/carbon... here is what I'm running. I've played with the gap from .035 to .050 no difference, still the black spot....
200 I-6, rebuilt 2500 miles ago
Autolite 1100 from Pony carbs, same age as rebuild
new wires
new dizzy cap
petronix 1 and flame thrower coil
timing is good
compression 140-150 accross the board.
thanks!
spots or crud?
crud would be an oil leak on the valve stem boot thingies
what are they called?
HI READ THIS
It talks about black spots on the porcilen part
Preignition/Detonation
Porcelain = the porcelain shows up preignition/detonation, it will not accurately reveal jetting/air/fuel ratios. To look for the first/beginning signs of detonation, search the white porcelain for tiny black specks or shiny specks of aluminum that have fused to the porcelain. When detonation occurs, part of the air/fuel mixture explodes instead of burning, the explosion is heard as a "metallic knock", this audible knock is the result of a sound shock-wave, this shock wave travels back and forth across the clearance volume "disrupting" the cooler boundary layer gases that cover the entire clearance volume area. This disruption allows "more" heat to be transferred into parts, especially, domes/piston tops,...along with the very rapid rise in pressure like a hammer blow, pistons can get torched with melted sides and holes !!! With the early signs of detonation, the shock-wave will also rattle rings causing the tiny amounts of oil that now gets by rings, to be fused to the white porcelain as tiny black specks, also fused as specks are soot that was clinging to clearance volume surfaces in the relatively "still-air" of the boundary layer. One step beyond the black specks, will be tiny specks/balls of aluminum coming off the pistons that will be fused to white porcelin,....the next step to be reached is occasional pieces of the porcelain being broken-off as detonation gets worse, ETC. Soon after that are holes, blown head gaskets, broken connecting rods, ETC.
NOTE> additional signs of beginning detonation are piston rings. By comparing ring's "free-diameter" to "out-of-box" free-diameters of new unused rings will reveals beginnings of detonation before much harm is caused !!! This is a result of the above previous explanation about heat being transferred more readily because the of the relatively insulating/cooler boundary layer being disrupted by the shock-wave. A piston ring is a simple spring, when a spring is over-heated it will loose tension.
Center Electrode = the very tiny sharply defined porcelain -"ditch" that encircles the center electrode, will also show up early signs of preignition/detonation and the wrong heat-range. Look for signs of the ditch beginning to be filled up with melted porcelain, you will need a 5x or 10x magnifying glass.
hope it helps
tim
