Spark plugs for turbo,s
Any thoughts on turbo specific spark plugs or is a good set of standard plugs the go :oops:
If you can find them, and they are out there, I'm using the AR-33's racing plug (autolite). Don't know how many steps colder, but they are more than one or two I know of. I have my gap set at @ 0.027", too big a gap and you will blow the spark out with a turbo engine. This is with 10 psi of boost. Hope that helps.
Kirk
We've used the AR-33s and they work fine. Right now we're using the NGK equivilant, but I don't recall the PN off hand.
We've got our's gapped at .025".
When the aluminum head comes out then you'll need the Autolite AR3934s.
Later,
Will
Cool guys, Thanks. Ive just about got it all together now 2v head is on , Turbo is all mounted alternator has been relocated lower, Ive put a new accelerator pedal and cable in Just need to finish off running the return line and fuel pump then she,ll be all go hope to have it running by xmas
Compliments of the season :wink:
