Starting Woes Part Two! Changed Ignition Switch
Okay, I went out and purchased a new, higher quality ignition switch, and to my frustration, it did nothing to change my situation. :x I still get a full, strong crank, but the second i let off the key it stops....next step is to hot wire the care and check the wiring, but if that doesn't work...i'm not sure what to do....
Thanks for all the input from the last post....and of course, any further is welcome! :D
it helps to keep everything in the same post, then people know what's already been done
you do have a constant 12v to the coil with the switch on, right?
because if it's starting while you're cranking it, then dying immediately after, i'd check and make sure you have enough voltage
how's your starter relay? if that's crappin out then that could cause it
