Stock 200 VE?
Bort62
2K+
Anyone want to hazard a guess?
What is peak power RPM for a stocker anyway... I am going to guess about 65% VE at peak HP...
StrangeRanger":s4pcayhp said:
What is the rated HP and RPM?
Or better yet dyno numbers on a stock engine since rated numbers from that era are...um...misleading
Dyno numbers on a stock or near-stock engine would be fantastic. We could back effective VE out of that to some degree of accuracy.
mustang monthly did a dyno tune on a 200 and 289 2bbl. The 200 1bbl made 77 hp at 3100 rpm and 124 lb of torque at 2900. The 289 stock made 115hp and 200 ft pounds.
Using those numbers a rough approximation using Ray Hall's turbo calculator with boost at zero and turbo efficiency at 100% and 27°C intake temp gave me right around 56% at 3100 and 54% at 2900. Certainly nothing to write home about but it seems a bit low even for the log head..
Using the same conditions an EFI 300 gives something like 67% VE, a number which seems fairly probable
56% does seem extremely low... I know we hate the log, but I don't think it is that bad.
Did you compensate for drivetrain losses ?
I can see the stock exhaust manifold screwing things up like that.
What were Ford thinking; they'd turned out cast shorties themselves (for the Y-block) only three years prior?
Pretty easy to work out, all you need is peak torque and rpm.
e.g 237 Nm @ 2400 rpm = ~60kW
100% VE @ stoich would be =~75kW
So actual VE = 0.8
but more realistically it will be fueling a little richer at peak torque so the max expected in today's engines would be about 66kW.
Or we can run the numbers this way:
77 HP @ 3100 RPM
77 HP x 0.5 lbs of fuel / hp-hr = 38.5 lbs of fuel/hr.
Assume at WOT and full load that A:F = 12.5:1 or 481.25 lbs of air/hr.
Air has a density of approx .075 lbs/cu ft, so: 481.25 / .075 = 6416.66 cu ft/hour or 106.94 cu ft/minute which equals 184,800 cu in/min
At 100 cid intake per rev, 3100 RPM would be 310,000 cu in per minute.
VE = 184,800 / 310,000 = .596 or just under 60%
Obviously, this is an approximation because it ignored the volumetric contribution of the fuel vapor and YMMV
Gee you guys and imperial :lol:
77hp ~= 57kW
3100 rpm on 3.277 litres = 3.277 x 3100/120 = 85 l/s
85/0.868 = ~98kW at stoich
VE = 57/98 = 0.58
Is that 3100 peak torque? Because that's where the measure is.
http://fordsix.com/forum/viewtopic.php?t=32577&start=0
Perhaps a more relevant dyno pull. Not stock, but a lightly modified 200.
119 hp @ 5100
143 ft-lb @ 3100
Or maybe most interesting as what a few simple modifications can do to an otherwise stock motor. I think that anyone looking for a properly sized turbo (the idea behind this whole thread) for a basically stock 200 would not object to a cam upgrade, bigger carb, and a little tuning.
77hp ~= 57kW
VE = 57/98 = 0.58
Bloody metric system.
The torque peak was at 2900.
I was using max fuel consumption at the HP peak of 3100 under full load
What is more interesting is that by two very different methods, we came up with virtually the same number
That can be dangerous, but independent correlation is usually a good sign...
119 hp @ 5100
143 ft-lb @ 3100
using my method I get 56%
using XPC66's method I think I get 64%
Still not very impressive.
No, not really. There are a few things that aren't being accounted for, however.
Parasitic losses in the engine, accessories, and drivetrain - for one. If we say 15% for drivetrain, and 5% for WP + alternator... that puts us a lot closer to what seems reasonable.
VE is directly correlated with thermal power. We have all sorts of losses and inefficiencies before it gets to the rear wheels. I'm not sure how good of an estimate of true VE we can get. We can, however, get an "effective VE" that takes all of those losses into account - but that is relatively useless for us when trying to establish compressor inlet CFM.
I wouldn't be using vehicle dyno figures if accuracy is the objective.
An alternator for test condition is only going to be drawing about 4 amps = 48 watts (0.064 hp) and even pumping 1.8 l/s, a water pump only uses about 120 watts (0.16 hp).
