stil bizzy with the car , love to work out side when the wetter is good . got also good light then , but i,m tired of rolling again and again the car out the carpport , because i stil cant drive , the shaft and joint,s are not fitting and i,m waiting for mij T5 to arrive !
got the "5 lug 8"" under the car and stil the 3.03 3 gear box from the 6 cyl .. got that problem i got 2 drive shafts . 1 for the 8 rear and T5 and 1 orginal 6 l !
both not fitting ! so i mild some caps that attach the orginal joint from the 6 and attaching also the 8"" axle ! verry simple solution , just some stupid little caps , they come over the orginal joint caps from the 6 shaft !!!, bolt up the drive shaft from the orginal 6 cyl manuel to the new 5 lug axle and i can drive !!!!
