I'd like to know who can build a 350hp 302 for $2500.  I say they are full of it.  You can't even make a 300 hp 302 with stock Ford Windsor heads.  You have to go aftermarket to do that, whether it's Motorsport heads or any number of other companies heads.  I've built a number of 302's and you can make 350 hp with a 302, even 400 hp without stroking it, but it won't be very streetable, and you sure won't do it for $2500.  You might get away with $2500 in just the heads, if you're lucky.  I've got between $6K & $7K in the current one I have to make 400hp and I bet it's only making 385 hp in reality.  The power band is 2500-6500 rpm, so it's kind of streetable.  The manual trans makes it that way.  You can really feel it pull from 2500 rpm up.  It started out as an XB3 345 hp crate motor with X-303 heads, a B303 cam and standard bore.  The heads have been fully ported, including port matching to an old Shelby style high rise dual plane intake.  Rockers were changed to 1.7's.  I know I could make more power by going to a more radical cam, and a single plane intake, but it would make it even less streetable.  It has a Demon 650 carb and aeromotive fuel system feeding it.  The short block was disassembled.  The pistons were weight matched, rods balanced and aftermarker ARP bolts were used.  The crank was microplished and oil holes chamfered.  The whole reciprocating assembly was balanced.  It has a DSS main girdle, crank scraper and ARP main studs.  There were other things done that I will not reveal, but anyone that races SBF's know the standard old tricks. Just like others have said previously, it's still just another cookie cutter SBF.  It has been done to death, and I have done it too.  That's what excites me a bout them darn INLINE 6 CYLINDERS!  They are different and it's something exciting because it's different.  My $.02
Darrell
