This post is for those that want to detail their Ford's and Mercury's in the correct factory engine colors that Ford used by the Model years. The detailing that Ford used on the early model engines in late 1959 through the end of 1965 year models is my personal favorite, plus the correct color was also another way that mechanics could quickly ID the engine size of these early Fords.
Of corse over all the years since these cars were new many have changed the engine colors during an engine rebuild, valve job or other repairs so these colors can be almost anything now and those are for sure the owners preference or choice to change them to what they want from how Ford orginally built them. Please PM me with pictures that you might have to submit of orginal cars or period correct restorations of engines, along with any addictions or corrections you might have, Enjoy
On the 1960 to 1962 cars the engine compartment was painted same as the exterior body color except for the Black cars that got sprayed or resprayed in Semi Gloss Black, Duplicolor's DE 1635 or Krylon 1613 is a good match. The 1963 to 1965 cars engine compartment were all painted in Semi Gloss Black too. The bottom of the Hood was painted in the exterior body color. The engine compartments were painted before the body started to be assembled. Brake lines and the bolts holding the fenders on were not painted and left a natural steel.
Here some pictures (below) and info on correct colors for a restoration of the early Ford Falcon and also the Mustang six engines. Ford painted the assembled Engine long-blocks, IE the block, head, front cover, water pump if cast iron, and oil pan, all in Gloss Black through the end of the 1965 year models, this included paint covering all the hardware (bolts etc.) Duplicolor's 1605 or Martin Seynour 7882 is an excellent color match. For the accessory parts like pulleys, fans, starters, generators (except for the generator or Alternator pulley and the fan behind it they are left natural steel), generator or alternator brackets & belt adjusters, etc. these were all painted Semi Gloss Black a very good match is Duplicolor's 1635.
The valve covers were painted separately from the engine, their color (for up to end of the 1965 year models) is one way that Ford and other Service Tech's used to ID the different engine sizes quickly. The Valve Covers were installed near the end of engine assembly using natural metal bolts with special integral lock washers. The oil cap breathers were painted the same color as the valve cover.
Ford engine colors
1960 to 1964 Falcon 144 engine was the base engine for the new for 1960 Falcons
Engine/Part. Color
144 Cu.In. Valve Cover Medium Blue Duplicolor's DE1606 or Martin Seynour 7958 Is reported to be a good match but I have not used it personally valve cover bolts are a natural metal
144 Cu.In. Air Cleaner Medium Blue Duplicolor's DE1606 or Martin Seynour 7958
144 Cu.In. Block, Head, Oil Pan, Gloss Black Duplicolor's DE1613 or Martin Seynour 7882 is good match
This is a 170ci six cylinder it was an optional engine in the Falcons starting in 1961 it was the standard base engine used in the 1962 Failane, as well as the 1964 1/2 Mustang's in their first 5 months of production. Info I have says it has a red valve cover and air cleaner but I remember them being more of an Orange Red as were the early 170 Falcon motors. The Valve cover bolts are a natural metal.
1961 to 1965 Falcon, Fairlane, and Mustang 170 six Engine Color Reference I am not sure if I can agree with this being the same as the 200's color
Engine/Part Color
170ci valve cover Orange Red Duplicolor's DE1605 or Martin Seynor 7992 the valve cover bolts are a natural metal
170ci air cleaner Orange Red Duplicolor's DE1605 or Martin Seynour 7992
170ci block, head, oil pan Gloss Black Duplicolor's DE1613 or Martin Seynour 7882 is good match
Ford 170 Six engine
Here pictured is a 200 six they were introduced as the base engine in the 1964 Fairlane. They were also an optional engine in the 1965 Falcon and also became the standard base engine for the 1965 Mustang. Looks much the same as the 170 it replaced, with the exception of the deeper red valve cover and air cleaner colors. Valve cover bolts are natural metal.
1964 the 200 Falcon, Fairlane, and Mustang 200 six Engine Color Reference
Engine/Part Color
200ci valve cover Red Duplicolor's DE1605 or Martin Seynour 7992
200ci air cleaner Red Duplicolor's DE1605 or Martin Seynour 7992
200ci block, head, oil pan Semi Gloss Black Duplicolor's De1613 or Martin Seynour 7882 is good match
Ford 200 Six engine
For the 1966 year models and later Ford engines they were no longer color keyed to specific engine models, all Ford engines were now painted a Ford Corporate Dark Blue. This was the new color for all Ford engines for 1966 and later. As before the entire Engine long block was painted after it's assembly and the valve covers were painted separate and than installed on the engine with the same natural metal bolts with the special integral lock washers as before. Some claim the 1966 and 1967 engines were the same color as the 1968 up Corperate Ford a Dark Blue, I can't say I agree with this as I remember them being a lighter Blue, then those of the later 1960's. To add further confusion many auto parts companies market 3 different Ford Blues.
In my opion for the years 1966 and 1967 all Ford and Mercury engines were painted a different Lighter Blue! Duplicolor's DE 1621 or Pladtickote # 205 Old Ford Blue is a close match to what I remember. If you plan to enter your car in shows you might want to find out for sure from the Judgeing / Tech's which engine color they except as original for the 1966 & 1967 Model models
In 1968 to 1972 170 six'es were still being used they were the base engines in the Falcons, Comet's, and the new 1970 Maverick's. They are painted the same as the 200's and 250's see below for example.
This is the 1966 200 engine (in the below picture) the air cleaner is made a little different from the 64 1/2 and 65 engines. All Ford engines were now painted in the Ford Blue starting in 1966, Valve cover bolts are the natural metal. The Sports Sprint models have a chrome air-cleaner housing, as did the 1966 Sprint 200, made available during Spring 1966.
1968 up Falcon, Fairlane, Maverick, Comets, and 1968 to 1973 Mustang 200 six Engine Color Reference
Engine/Part Color
200ci valve cover Dark Ford Corporate Blue Duplicolor's DE 1606 Dark Ford Blue or Plastickote # 224
200ci air cleaner Dark Ford Corporate Blue Duplicolor's DE 1606
200ci block, head, oil pan Dark Ford Corporate Blue Duplicolor's DE 1606
1966 Ford 200 Six
The 1969 up Falcon, Fairlane, Maverick, Comet, Granada, Monarch, 1969 to 1973 Mustang 250 six Engine was also painted the same Dark Ford Corporate Blue.
For the 1968 up color of Ford Corporate (Dark) Blue, Duplicolor's 1606 matches this. Some other brands that also match the Ford Blue are Krylon's Ford Dark Blue and Plasticoat Royal Blue 1134. For the accessory parts like pulleys, fans, starters, alternator brackets & belt adjusters, etc. these were all painted Semi Gloss Black a good match is Duplicolor's 1635. Good luck
