All Small Six The 'Ideal' 200 Built By Committee
1966Mustang
ALL THE THINGS
Staff member
Subscriber
  • I picked up a 1978 200 a while ago, for no other purpose other than I was bored and needed a road-trip to New Jersey.
  • The head has been cleaned and no cracks found. It is sitting on a shelf, partially pocket ported ... (for sale soon)
  • The block has not been inspected yet. It is sitting on an engine stand. Assume it's good and can be bored.
  • Also assume it's going in my 65 Mustang Coupe. My HP goal is... about 400ish
  • Reply with your suggestions/ideas on the Carb/EFI, Ignition, Pistons, Cam, AL Head?, Tranny, Reardiff, Exhaust, Turbo???
  • Upvote the replies you like, downvote the ones you don't (up/down arrows on the right of the replies).
  • Let's have some fun with this!
As 'decisions' are made, they'll be posted here, subject to change.
Added Google Sheet Feb 9, 2020 for P/Ns and Purchasing Dept. Progress...
Mostly Decided:
  1. Holley Super Sniper 4150 650HP PART# PART# 550-520 - https://www.holley.com/products/fue...sniper_efi/sniper_4bbl_tbi_kits/parts/550-520
    1. Sniper ignition, etc
  2. VI AL Head #10269 Ported - https://www.vintageinlines.com/product-page/deposit-only-aluminum-head-package
  3. Extended Valve Stems +.30 - re note to Matt @ VI stem add +.30 to length as default
    1. SI
    2. Manley
  4. 1300909705/177210 BW Airwerks Turbo S300SX-E 8378 61.44mm T4 .88 AR Journal bearing
  5. F38-Black-14.5psi - Tial F38 38mm Wastegate Black 14.5psi
  6. QBOV-Black-11psi-AL - Tial Q BOV 50mm 11psi
  7. Camshaft - Solid-Lifter Cam CompCams Card 68362
  8. Lifters - Oil Hole Solid Lifters CompCams SKU 817-12
  9. Roller Rockers - RAU - F-44RA & F-44RRA? - http://rockerarms.com/pages/rollerfordcad.html
  10. Adjustable Timing Gear Set - PART# JPP-200-DRC - https://www.vintageinlines.com/product-page/dual-roller-timing-chain-set-170-200ci
Developing and Can-Do:
  1. Connecting Rods - Pauter Engineering FOR-235-565-1248F
  2. Custom forged 2618 alloy pistons - http://racetecpistons.com/
To be Developed or Figured on:
  1. Equal Length Header/T4 Collector
  2. Harmonic Balancer / Damper
    1. http://www.atiracing.com/contact/contactati.htm
    2. B-H-J - Spoke with Chris, good conversation
    3. Fluidamper contacted - nope
    4. ATI - too much normal stuff to do custom.
  3. Oil Pump
    1. Contacting Pauter on oil pump mods.
    2. 250CID Pump, Adapter and drive from D2S Racing Products Inc. ( @drag-200stang )
  4. Oil Pan
    1. Canton?
    2. Modify stock pan, develop windage kit
Added Jan 29,2021 7PM
Vendors Contacted/Emailed:
Magnum Machine Inc.
https://www.magnummachineincorporated.com
Magnum Machine Inc.
921 Business Park Dr
Chesapeake, VA 23320
Telephone: (757) 424-1440
FAX: (757) 424-6210
Owner says- "No prob, I like the oddball builds"
Rocker Arms Unlimited - https://rockerarms.com
16575 Clear Creek Rd.
Redding, CA. 96001
Tel: 530-242-1316
Fax: 530-242-1332
Email: rockerarms@rockerarms.com
re: @bubba22349 's suggestion on roller rocker availability, made in usa
Pauter Machine - https://pauter.com
Don Pauter
367 Zenith Street
Chula Vista, CA 91911
Tel: 619-422-5384
Fax: 619-422-1924
Email: info@pauter.com
Custom Connecting Rods - FOR-235-565-1248F
And oil pumps...
https://pauter.com/parts/oil-pumps/
contacting about HV 200 oil pump mods.
RaceTec Pistons - https://RaceTecPistons.com
Randy Gillis
15681 Computer Lane
Huntington Beach, Ca 92649
Tel: 714-903-4362
Fax: 714-891-0190
CAA Racing Products/Protohawk (torque-plates/other engineering)
https://www.protohawk.com/ https://ccaracing.com/
Michael Gallo
- offered to sanity check our torque plate. because... no one wants to wreck a chunk of stock :D - which is awfully gracious of the owner.
- Makes insert bushings too: https://ccaracing.com/engine-block-tooling/
EDIT:
This post is made 1 yr after project completion. It was not an exercise but a real life
attempt to develop a motor. VI heads (ci & vi together may have made ~ 200 cast/sold)
are not in production at this time.
-as I read the "title page" to this thread in some ways it is all I need to make a tester (of course @ 10K$
some will wanna C the data/choices made to get to this 'parts sheet', so...
Have all these items been documented as available (yes, I C notes that some can B supplied w/plenty notice)?
But there are no "may be"? or unavailable?
Thanks so much for posting.
AND
developing!
If it is complete - "stickie-a-tize" ?
Has anyone on here heard about this company in Argentina? Unfortunately, I do not speak Spanish, but I still find this interesting. This company has developed a four valve OHC alloy cylinder head for the Ford 221SP engine, Chevrolet 250 and a Dodge six cylinder for Turismo Carretera racing.
Search for Argentina - I believe there is a member importing or trying to import these parts?
big following there (Argie & Venesuala). If U ask me I’ll telll ya (fact or fiction) “Those R not for street use. Must B certified race team to run.” Even worse chance for export?
Now,
that does NOT mean we should not study and copy...
BUT...
this thread is for something We Can Have
Mostly Decided:
    1. SI
    2. Manley
  3. Oil Pump
  4. Oil Pan
    1. Canton?
Magnum Machine Inc.
Magnum Machine Inc.
FAX: (757) 424-6210
Redding, CA. 96001
Tel: 530-242-1316
Fax: 530-242-1332
Don Pauter
367 Zenith Street
Tel: 619-422-5384
Fax: 619-422-1924
And oil pumps...
Randy Gillis
15681 Computer Lane
Tel: 714-903-4362
Fax: 714-891-0190
Michael Gallo
Do you have the VI AL Head #10269 Ported? It seems to made of unobtainium at least for the foreseeable future.
many? some? would go on w/other plans... eyes pealed for a seller of the CI or VI head by ‘one of us'
who shucks it. I no guys as enamored w/the ford6 as I who went up the trial ladder (1st 1v carb, then 2, raised ratio rockers, then to internal improvements, etc) and abandoned the project to swap ina bent8... go thru that also till the 'top’. “I wasnt sure if it was what I wanted. I guess
it wasnt, went on to the 8..."
