The Mustang is now running after a long 2bbl carburetor upgrade project. Here is how the first startup went:
I cranked it over while Al (my girlfriend's father) was set and ready to tune the carburetor. It turned over but died. I turned it over again and kept giving it gas and it started. He told me to turn it off so I turned the key to the "Off" position but the engine did not shut off. I thought the accelerator linkage might have been stuck so I started pulling up on the gas pedal. That did nothing but there was noise coming from the starter motor. Al got a wrench and disconnected the the negative battery cable. The car then shut off. The fuel line was also leaking. The hose clamps just needed to be tightened. I turned it over again and kept on the gas. Al started to tune the carburetor while I manned the controls in the cockpit. The carburetor is now pretty well tuned. Al gave me an old Sun Dwell/Tachometer. I am going to see if it works tomorrow. Sometime this weekend I will bring the Mustang over to his house and we will get out the timing light and set the timing, plugs, gaps and do some more tuning.
The air cleaner I got does not fit correctly on the Holley 5200 2bbl carb. It is a chrome Hi-Po air cleaner and I thought they were used on both 2bbl and 4bbl carburetor. There is a big gap on the right side (driver side) of the air cleaner/carburetor. This Saturday Al and I will be going to a speed shop and getting an adapter plate.
I would like to thank everyone who helped me finish the carburetor project. It was a b!tch...mainly because I did not plan everything out. I can change my sig line now.
Next comes the shift kit. I have a 1965/66 C4 Transgo shift kit. When I went to install it I noticed that the valve body was dated 1968.
Does anyone want to trade a 65/66 C4 Transgo shift kit for a '68 C4 Transgo shift kit?
Thanks again,
Justin
Future Mods:
2bbl carb, shift kit, T5
Thanks again,
Justin
