THIS HAS TO CHANGE..NOW!!!!!!!! (Radiator problems)
blueroo
This weekend I was supposed to be in Cincinnati for the Fairlane Club Nationals. Got up at 4 this morning, drove out of the driveway around 530. Went to the gas station and filled up. The radiator was steaming a little bit. We had to come back home though to grease the front suspension. I had to inside and when I came back out my dad said we can't take my car and pointed to the massive puddle forming underneath my radiator.
It had been repaired umpteen times before I bought the car, and once since I've had the car. A couple weeks ago it started to leak slightly, so I put a tablespoon of black pepper in and it was fine. This morning before we left to go fill up, my dad put some of that aluma-seal or whatever in the radiator.
So now, I'm replacing the radiator. I don't want a stock replacement but I'm a little restricted on size due to the frame rails. I can safely go to 24" wide by 20" tall. I'm considering a 4 cyl Ranger replacement due to the fact it deals with hotter temps and doesn't have a problem, but I'm not sure if that's the route to go.
I'm also going to an electric fan. And I'd like to change the water pump to the A/C unit but that created a problem. I can't find it. One post here listed it as Cardone #58220 but nobody seems to carry it. Has it changed numbers?
My first choice is aluminum as I've had a great experience with mine since installing it into the Falcon. Although they are more expensive.
If price is a factor, just hit the local autoparts store and pick up a V8 radiator for your car. It will be a bolt-in and an increased cooling capacity (3 core).
When the cooling system is clean and working correct, it is more than efficient enough. I think any new radiator and a strong water pump will be all you need.
As for the electric fan, I'm a fan. :roll: The beauty of it is is it only comes on when you need it most, when stopped. At speed, a car doesn't need a fan. In contrast, a mechanical fan works worst when stopped.
The V-8 one is a bolt in except the outlet on the bottom is on the wrong size. When I went to Advance, the only six cylinder radiator that they had was a 3-row as well. It's a Modine unit and was about 120 bucks.
However, the radiator from Advance is way thicker than stock. I coudn't fit the stock fan back on. I went to a flex fan, it fit but was so loud I took it off.
I took the add=a-pulley from the harmonic balancer, removed the fan spacer from the stock fan, and put it back on.
Also, the water pump I got from them is the A/C one. I didn't ask for it, but that's what they had. You can tell by looking at the impeller. If it has a flat disc on the back, then it's the A/C version.
One of these days I'll put an electric fan on, but I have more pressing concerns.
I decided to go with the stock replacement...picked it up at Autozone for $217 ($230.01 when it was all said and done) and I'm putting it in either tomorrow or Sunday afternoon. Fan and pump will remain same...for now.
What I do need to know however is how to completely flush the system before I put the new radiator in. Any suggestions?
$200! Wow, that is high. I'd say about $100 more than it should have cost for a stock set-up.
I paid $190 delivered, for my aluminum set-up from ebay.
I know it was a bit high, it was actually a lot cheaper than the company I usually go with, Dearborn Classics, they wanted 270.
I wanted an aluminum radiator, but the problem is the Fairlanes have a rather odd radiator support/surrounding area. I could safely go 2 inches wider and one inch taller than stock without having to cut the frame. I couldn't find an aluminum radiator that size.
Even still it was a tight fit. The flanges on the one I got from Autozone were too tall...I had to cut them down (or I guess you'd say up) so they wouldn't hit the frame rails.
I'm not 100% sure on this, but it appears to have provisions for an electric fan. It also has ports for an automatic transmission cooler, which I don't have and have no plans to ever put an automatic in, but nonetheless it's nice to have, who knows, I might be able to put an additional tank in to increase the capacity.
And the car runs about 10 degrees cooler.
do you happen to have the part number you used?
I am looking to change back to a downflow radaitor and was thinking of a 302 early mustang radaitor (alloy direct fit one) not concerned about outlet size or location too much but mostly if it will "bolt in"
With the radiator out remove the thermostat and reinstall the upper hose. Stuff the end of a garden hose in the upper hose and flush away. You may want to check local rules about discharging coolant on the ground.
